This page applies only to Superwhisper on iOS. macOS and Windows are not affected by these changes.
What Changed
Apple’s iOS 26.4 update changed how third-party keyboards work. A behavior Superwhisper previously relied on is no longer available:- No automatic app return: after tapping the Superwhisper keyboard button to start dictation, iOS no longer returns you to your previous app automatically. You now swipe back manually.
How Superwhisper Adapts
All of Superwhisper’s existing modes, including Message, Mail, Note, and any custom modes you’ve created, continue to work as before. The only change is the extra swipe back after starting dictation.FAQ
Why do I have to swipe back to my app after starting dictation?
iOS 26.4 no longer allows third-party keyboards to programmatically return you to the previous app. You’ll need to swipe back manually after tapping the Superwhisper button.
Do these changes affect macOS or Windows?
No. These are iOS-specific platform changes. The macOS and Windows versions of Superwhisper are unaffected, and features like auto-activation rules continue to work as expected.
I'm seeing unexpected behavior beyond what's described here
If you’re experiencing issues not covered above, please contact support@superwhisper.com with your iPhone model, iOS version, and Superwhisper version. A short screen recording of the problem is a huge help too, if you can include one.
Can I report this to Apple?
Yes, and we’d encourage it. The more people report the issue, the more likely Apple is to address it. You can file feedback using Apple’s Feedback Assistant. If you do, consider referencing feedback ID FB22247647, which tracks the underlying
hostApplicationBundleID bug affecting third-party keyboards.
